https://help.tallysolutions.com/docs/te9rel49/Control_Centre/My_Sessions.htm
My Sessions
The My Sessions display important information about the remote login session for a user. The session information is displayed on logging in remotely from another computer or not logging out from an earlier session. This information helps the user to analyse sessions that are not required and delete them.
This screen displays the Name or IP Address of the computer From where the user had logged in, the Start Time for each session, the time when the Last Activity took place along and the Status of an individual session for the respective User ID which is displayed against the Tally.NET ID field.
In the Control Centre screen
  • Select S: My Sessions and press Enter
The My Sessions screen appears as shown:
Button options in My Sessions screen
F3: SessionWise
Press F3 to view the screen based on the Session Types:
  • Remote User for Remote Company
  • Control Center
  • Support Center
F5: Refresh
The button can be used to update My Sessions screen with latest log ins
F12: Configuration
The following options can be used to configure My Sessions screen:
  • Status
The Status of the user - Active or Idle
  • Type
The Session Type - Remote User for Remote Company/Control Center/Support Center
  • Group By
This option servers the same purpose as F3: SessionWise - the report will display information by categorising them based on the Session Types
D: Delete Session
  • Select the required session.
  • Click D: Delete Session or press Alt+D to delete the session.
