You can create multiple Cost Centres in this mode.
Go to Gateway of Tally> Accounts Info.> Cost Centres> Create (under Multiple Ledgers)
The Multi Cost Centre Creation screen is displayed as shown.
A brief explanation on each of the fields in the Multi Cost Centre Creation screen follows.
Select a particular Cost Centre as the parent Cost Centre, to create cost centres under it. If you wish to create cost centres under different Cost Centres, select All Items and specify the relevant cost centres in the Under field.
Enter the name of the Cost Centre to be created.
The Parent Cost Centre selected in the Under Cost Centre field displays automatically in the Under field for Cost Centres created newly. If All Items is selected in the Under Cost Centre field, you have the option of selecting the Cost Centre from the List of Cost Centres.
You can display the details of multiple Cost Centres at a time in this mode.
Go to Gateway of Tally> Accounts Info.> Cost Centres> Display (under Multiple Cost Centres)
Select a Cost Centre or All Items to display the details of all the Cost Centres under it. Alteration of Cost Centres will not be possible in Display mode.
Note : The alias option will not be available in Multiple Cost Centre Creation mode. However, you can specify aliases to Cost Centres by selecting each cost centre.
'Creating Multiple Cost Centres' has been shared with
