Tally.ERP 9 Help file is structured in such a way that it provides easy navigation between topics and facilitates easy search.
The comprehensive Local Help covers basic and advanced operations. It is context-sensitive and extracts help on topics related to the current screen in Tally.ERP9.
To access the Local Help follow the steps shown:
Press Alt+H or click on H: Help from Tally.ERP 9
The Help Options screen appears
By default the Search in field displays Local Help and press Enter to continue. As Local help is Context sensitive, based on the screen from where you have clicked on Help, information about that screen will be displayed for reference.
Tally.ERP 9 displays the Local Help result (Tally.ERP 9 Reference Manual) only when the tallyerp9ref.chm file is available in the Tally.ERP 9 folder. The tallyerp9ref.chm is the Local help source file.
If the tallyerp9ref.chm file is not available in the Tally.ERP 9 folder and if you click on H:Help button and selected Local Help as the help option, then the Application displays the message as shown
Press Y or Enter to view Tally.ERP 9 Download Center screen of Tally Solutions Website.
Select Tally.ERP 9 Reference Manual to Download
Here are some details on how to use this Local help file effectively. It is suggested to go through this topic to utilize the Local Help file effectively.
On the right (display) pane
Click border="0" /> Next button to navigate to the next topic.
Click Previous to navigate to the previous topic.
Click the green text to open the related topic.
The content followed by Note gives additional information related to the topic.
Using the left (navigation) pane
The navigation pane consists of three tabs - Contents, Index and Search
Tab |
Description |
How to? |
Contents |
Helps to navigate between the topics |
Click the symbol to expand and view the subfolders and topics. Click the topic to view content on the right pane |
Index |
Contains the alphabetical list of names and topics that are linked with related topics |
Select or type the keyword and double-click or click Display button. Select the most matching topic from Topics Found window and click Display button. |
Search |
Facilitates searching |
Type the keyword, and press Enter key or click List topics button. The topics related to the keyword are displayed. Click on it to view the same. |
Type your drop-down text here.
The tool bar buttons and their functionalities are given below:
Button |
What it does? |
Opens and closes navigation pane |
Opens the previously viewed topic |
Opens the next topic in the previously viewed sequence |
If you select Print button from the Contents tab, prints pages, headings and subtopics or the entire table of contents If you select Print button, from the Index or Search tab, opens the Print dialog for printing the current topic |
Opens a menu that provides access to Home, Show, Back, Stop, Refresh, Print, and Search Highlight On/Off |
'Tally.ERP 9 Local Help' has been shared with
