https://help.tallysolutions.com/docs/te9rel49/Job_Work/JI_Stock.htm
Stock
Stock reports displays the details of stock received from different Principal Manufacturers and from how many days the stock is with the Job worker.
To view the Stock reports
Go to Gateway of Tally > Display > Job Work In Reports > Stock
Stock Reports are
