https://help.tallysolutions.com/docs/te9rel49/Tax_Audit/Tax_Audit_1/TDS_Clarified_Summary.htm
TDS Clarified Summary
When the Client provides the necessary Clarification for a TDS Bill marked by the Auditor as Need Clarification, it will be listed under Clarified (To be re-audited) column in the Tax Audit Dashboard.
The drill down and other options for the FBT Clarified Summary is similar to the FBT Re-Audit Summary report. For details, refer to TDS Re-Audit Summary.
