https://help.tallysolutions.com/docs/te9rel49/Control_Centre/Test_Scheduled_for_Employee.htm
Test Scheduled - Employee Assessment
This folder displays the list of employees who have been assigned new test by the employer from any of the other folders.
To open Test Scheduled folder, from the Employee Assessment screen:
  • Select Test Scheduled folder and press Enter
The List of Employees screen appears displaying the name of those employees to whom tests have been scheduled as shown:
The following functions can be performed from this folder:
  • F1: Detailed: Allows you to view the test details of the employees, such as, E-mail ID and Test ID.
  • H: Hall Ticket: Allows the employer to view/print/e-mail  the hall ticket for the online/assessment test
  • E: Cancel Test: Allows cancellation of a test assigned to an employee. This button will be active only to the employees in Assigned status.
  • C: Add Comment: Allows adding comment to the selected employee.
  • V: View All Activities: Allows viewing of all the activities of a selected employee along with the comments recorded at each of the process level.
Online Test by Employee:
To take the Scheduled Test, the employee should follow the steps shown:
  • Start Internet Explorer.
  • In the address bar type www.tallysolutions.com/test
The Start Online Test page appears as shown:
  • Enter the Test ID which you had noted, in Please enter your Test ID here.
The Start Online Test screen appears displaying the Online Test Instructions.
  • Click Start Test
The Online Test Paper page appears as shown:
In the Online Test Paper page the following buttons perform the respective tasks:
  • << Prev go to the previous question.
  • Next >> go to the next question.
  • Test Completed indicates you have completed the test.
  • Show All Questions displays all questions of the respective question paper.
Proceed to answer the questions from the question paper assigned.
  • Click Test Completed to indicate that you have completed the test successfully.
On completing the test click Test Completed. A screen displaying statistics for the test taken appear as shown:
  • Click Yes to submit the test taken
  • Click Done to confirm submission
On completion the following screen appears:
The employee’s scorecard for the assigned test paper appears as shown:
The employer or the organiser of the online test can view the marks sheet by following the steps shown:
  • Login to the Control Centre
  • Select Jobs & Recruitments > Employee Assessment
  • Select Test Completed folder
  • Select the required employee
  • Click A: AnswerSheet or press Alt + A
Online Test Halts Abruptly:
In case the online test comes to an abrupt halt due to any one of the following reasons:
  • Power Failure.
  • Employee has accidentally closed the window.
  • The system has crashed.
In such cases, the employer needs to login to the Control Centre:
  • Select Jobs & Recruitments > Employee Assessment.
The List of Employees screen displays the Last Test Status column as Aborted for employees whose online test failed during the process.
  • Select the required Aborted candidate
  • Click R: Resume Test.
  • A message Are you sure to resume the test? Yes or No appears.
  • Press Y to allow continuation of the test for the same employee.
  • The Status under Last Test Status changes to In Progress as shown:
Resume the Online Test:
  • To restart the same test, follow the steps shown:
  • In the address toolbar type www.tallysolutions.com/test
  • The Start Online Test page appears. The employee should provide the same Test ID which was provided to him earlier.
  • The Online Test screen appears, click Continue.
