https://help.tallysolutions.com/docs/te9rel51/sync/Configuring_TSS_Features.htm
Configuring TSS Features
You can configure TSS features if you have enabled Security Control in Company Creation master.
To enable the Security Control feature
  • Go to Company Alteration (Alt+F3) screen.
  • Set  Use Security Control to Yes.
To configure the TSS features
  1. Go to Gateway of Tally > F11: Company Features > F4: TSS Features. The Company Operations Alteration screen appears.
  1. Enter the Connection Details.
Note: The Connect Name entered here must be entered during client rule creation.
  1. Enter the Connect for Remote Access details.
  2. Enter the SMS Access Details.
Note: The company name in the SMS Company Name field should not exceed 8 characters.
  1. Press Enter to save.
