https://help.tallysolutions.com/docs/te9rel51/Payroll/Creating_Canteen_Deduction_Pay_Head.htm
Creating a Canteen Deduction Pay Head
To create the Canteen Deduction Pay Head
  2. Enter the pay head name in the Name field.
  3. Select Deductions from Employees as the Pay Head Type from the List of Pay Head Types.
  4. Select Current Assets from the List of Groups in the Under field.
  5. By default, Affect Net Salary is set to Yes. Type No, if you do not want this component to be included in the Pay Slip.
  6. By default, the pay head component name entered in the Name field appears in the pay slip. Enter the Name to appear in Payslip if you want to change the default pay head component name.
  7. Select As User Defined Value as the Calculation Type from the List of Calculation.
  8. Press Enter to accept.
