While carrying on business it is common that the supplier gives discount on purchase cost and provides charged services like Packing of Material, Transportation, etc.
In this scenario, VAT is calculated on the Assessable Value which is arrived at by Deducting the Discount given and Adding the Packing Charges.
To create an entry for taxable Purchase with Discount and Packing Charges,
Go to Gateway of Tally > Accounting Vouchers > F9: Purchase
Enter the Supplier Invoice Number and Date.
Select the Party’s A/c Name from the List of Ledger Accounts.
Select the Purchase Ledger with the VAT/Tax class - Purchases @ 16%.
The VAT/Tax Class appears as predefined for the purchase ledger.
Select the Name of Item from the List of Items.
Enter the Quantity and Rate. The amount is automatically displayed in the Amount field.
Select Discount ledger from the List of Ledger Accounts (created under Direct/Indirect Expenses by enabling the Use for Assessable Value Calculation option).
Enter the Discount amount with negative sign.
Select the Packing Charges ledger from the List of Ledger Accounts and enter the packing charges in Amount field
Select the Input VAT ledger with the applicable VAT/Tax classification.
Note: Here Input VAT is calculated on Assessable Value (8,006,000) = Item Cost (8,000,000)- Discount (4,000) + Packing Charges (10,000).
In Brief Desc for VAT field, enter the brief description of the goods purchased under this invoice.
Note: The brief description entered about the stock will be captured in (F)Brief Description of Supply Box in VAT Annexure.
Set the field Show Statutory Details to Yes to view VAT calculation.
Enter the details in the field Narration, if required.
Press Y or Enter to accept and save.
Note: The assessable value of sales made using taxable VAT/Tax classification - Purchases @ 16% is captured in box 6 - TAXABLE Purchases (GENERAL RATE)(in Value EXCL. VAT) of Form VAT 3. The Input tax payable on taxable sales is captured in box 6 -VAT Charged field.
'Taxable Purchases with Additional Ledgers (Kenya)' has been shared with
