https://help.tallysolutions.com/docs/te9rel51/Advanced_Features/Advanced_Inventory_Features/Comparative_Job_Work_Analysis_report.htm
Comparative Job Work Analysis report
To view multiple Job/Projects.
The Job Work Analysis report supports details of Multiple Jobs in a single report. All these details are viewed as different columns with the help of New Column button. Alt+N
Comparative Job Work Analysis report will be displayed as shown:
Comparison of one Job with another Job:
The button Auto Column is  available in the report to view the period for a particular period that can be selected from the list. Refer Modify Reports for adding, deleting and altering columns. Press Alt+C.
Job Work Analysis report will appear as below:
Viewing any other Project/Job from the existing project Job Work Analysis report:
The button Alter Column is also available in the report to view the other job or Project Alt+A
Job Work Analysis report will appear as shown:
Press F4 button, to select the other Job/Project from the list.
It allows the user to drill down from Job Work Analysis report to voucher entry, to view a break up of Job/Project.
