A provision is made to generate ST3 returns in new xml schema: In compliance with the changes made to the xml file format and validation tool by the department, provision is now made to export the ST3 return in the new xml schema.
Now, CENVAT credit brought forward from previous return period is added to the CENVAT credit availed in current period to show the balance available credit.
Now Daily Stock Register displays details after filtering the items based on tariff selected in Select Excise Unit screen.
A provision is made to generate annexures without commodity names: VAT annexures of Chandigarh and Gujarat are now generated without commodity details when commodity is not tagged in masters. Exception is also created in validation to allow annexures without commodity details.
'Release 5.1.1 bug fixes' has been shared with
