https://help.tallysolutions.com/docs/te9rel51/Auditor_Edition/International_Audit/Verification_of_Balances_for_Group.htm
Verification of Balances for Group
To view details of transactions along with the Opening Balance and Closing Balance the user can drill down to the Verification of Balances report for the selected Group.
To view the Verification of Balances report a Group,
Go to Gateway of Tally > Analysis & Verification >  Verification of Balances
  • Bring cursor on the Amount field for the required Group as shown:
  • Press Enter
The Verification of Balances report for the selected group will be displayed as shown:
Drill down to Ledger Vouchers report is provided from the above report by keep pressing Enter on the Group name or a subgroup name and then ledger name.
