https://help.tallysolutions.com/docs/te9rel51/Payroll/Defining_Salary_Structure.htm
Defining Salary Structure
Salary Details is used to define the pay structure for an employee or an employee group.
To define Salary Details
  1. Go to Gateway of Tally > Payroll Info. > Salary Details.
To quickly enter the pay structure of each employee, define the Pay Structure for the Employee Group for an employee group using pay heads which are applicable to most employees. You can then copy and apply the same structure to each employee.
If required, you can add, delete. or change a pay head component or its value for individual employees. For more information, see Defining Salary Details for an Employee.
