https://help.tallysolutions.com/docs/te9rel51/Payroll/Enabling_Payroll_in_TallyERP.htm
Enabling Payroll in Tally.ERP 9
Payroll is a default feature available in Tally.ERP 9. Enabling Payroll is a two step process:
To enable Payroll in Tally.ERP 9
  1. Go to Gateway of Tally > F11: Features > F1: Accounting Features.
  2. Tab down to Cost/Profit Centres Management section.
  1. Set Maintain Payroll to Yes.
  2. Set More than ONE Payroll / Cost Category to Yes, to allocate employee cost by creating separate employee categories.
Note: You can enable More Than ONE Payroll / Cost Category option to Yes, where parallel allocation of employee cost/cost centre is required.
  1. Press Enter to accept and save, and return to the Gateway of Tally screen.
The Gateway of Tally screen appears as shown below:
More:
Enabling Payroll Statutory features
