https://help.tallysolutions.com/docs/te9rel51/Tax_International/Indonesia/Purchase_ledger_vat_indonesia.htm
Creating a Purchase Ledger
To create a Purchase ledger,
Go to Gateway of Tally > Accounts Info > Ledger > Create
  1. Enter the Name of the purchase ledger, for e.g., Purchases @ 10%
  2. In the Under field, select the Purchase Accounts from the List of Groups
  3. By default Inventory values are affected will be set to Yes
  4. Set Used In VAT Returns to Yes
  1. Select the required VAT/Tax Class, for e.g, Purchases @ 10%
  1. Press Enter to return to the Purchase ledger creation screen
  2. Accept the Purchase Ledger Creation screen.
Note: It is recommended that separate Purchase Ledgers be created for each of the purchase related VAT/Tax classifications.
