https://help.tallysolutions.com/docs/te9rel51/Creating_Masters/Inventory_Info/Locations_Godowns.htm
Locations / Godowns
Locations/Godowns are places where Stock Items are stored. You can monitor the location-wise movement of stock by creating multiple Godowns.
Example:
Suppose you have three Godowns, where you store the Goods. In Chennai, you have two Godowns and in Bangalore, one Godown.
You can create Godowns as shown below:
Godown
Under
Godown A
Chennai
Godown B
Chennai
Godown C
Bangalore
First you have to Create Chennai and Bangalore locations and then you have to create Godowns under the respective location.
Tally.ERP 9 has a default Godown named Main Location. You can alter Tally's default godown and create a new one. Tally.ERP 9 permits the creation of any number of godowns, under groups and subgroups to match the structure you need.
You can create Locations/Godowns only if Maintain Multiple Godowns is enabled in F11: Features > F2: Inventory Features.
Go to Gateway of Tally > Inventory Info. > Godowns
Note: The term Locations is displayed in the Inventory Info. menu, if International is selected under Use Accounting Terminology of in General Configuration (Gateway of Tally > F12:Configure) screen. If India/SAARC is selected, the term Godowns is displayed.
More:
Creating Locations/Godowns
Displaying and Altering Stock Locations/Godowns
Creating Godowns for Job Costing
