https://help.tallysolutions.com/docs/te9rel51/Control_Centre/My_TallyNET_Account_Single_Site.htm
My Tally.NET Account Single Site
On selecting My Tally.NET Accounts, the My Tally.NET Accounts screen appears as shown:
The My Tally.NET Accounts screen displays the User ID against Tally.NET ID field, the Account ID, Security Level, permission to access Tally.NET Server, Site ID (for Multi Site only), permission to Administer the Account and the account Status. It also displays the Account IDs that are associated with your Account, based on your requirement you may disassociate your Account ID.
  • Select the required Single Site Account ID and press Enter.
Note: Site ID will not appear when you have a Single Site Account.
To disassociate from another account, select the required Account ID and press Alt + D.
The Account/Site Administrator ID cannot be disassociated from associated accounts.
