https://help.tallysolutions.com/docs/te9rel51/Tax_India/Excise_Mfg/Configurations_for_Creating_Masters.htm
Configurations for Creating Masters
On this page:
Configuring Selection of Tariff Type
Configuring Tax Calculation based on MRP
Selecting multiple duty details
Configuring Modification of Nature of Removal
To configure selection of tariff type
  1. Press F12: Configure in the Excise Tariff Details screen
  2. Enable the option Enable selection of Tariff Type.
  3. Press Ctrl+A.
You can now select the Type of Tariff in the Excise Tariff Details screen.
Calculating Duty Based on MRP
To configure calculation of tax based on MRP
  1. Press F12: Configure in the Excise Tariff Details screen.
  2. Enable the option Enable tax based on MRP.
  3. Press Ctrl+A.
  4. Set the option Calculate Duty on MRP in the Excise classification creation  screen.
  5. Enter the Abatement %, as required.
Note: If the option Calc Duty on MRP? is set to No, then the cursor skips the field Abatement%
Selecting Multiple Duty Details
When an excise stock item attracts multiple duties, the details for each type of duty can be defined in the tariff.
To define multiple duty details
  2. Enable the option Enable Multi Selection of Duty Details.
  3. Enable this option Override Valuation Type for Duty Head  to change the Valuation Type which is preset for the tariff.
  4. Enable the option Allow Notification Details, if required.
Note: If the option Allow Multi Selection of Duty Details is set to No, then the cursor skips the fields Override Valuation Type for Duty Head and Allow Notification Details.
  1. Press Ctrl+A.
  2. Select the Type of Duty and set the Valuation Type, Rate and Notification details.
  3. Press Enter.
  4. Select the Type of Duty and define duty details.
Based on the state specified in the party's address, the nature of purchase will be inferred by  the system. For example, if the party's state is the same as the company's then, the nature of purchase is by default set to Domestic. The default nature of purchase can be modified by the user when required.
To configure modification of nature of removal
  1. Press F12: Configure in the Excise Details screen.
  2. Set the option Enable Nature of Removal to Yes in the Configuration screen.
  3. Press Ctrl+A.
  4. Select the Nature of Removal, as required in the Excise Details screen.
Note: The option Allow Nature of Removal is enabled, by default.
Recording the Excise Registration Details
To Record the Registration Details in a Party Ledger
  2. Set the option Allow Registration Details to Yes in the Configuration screen .
  3. Set the option Allow Importer's ECC to Yes if the party is an importer.
  4. Press Ctrl+A.
  5. Enter the Registration Info of the party.
Defining Excise Details Based on the Date of Applicability
To define excise details based on the date of applicability
  1. Click L:Details in the Excise Details screen. The Excise Tariff Details screen appears.
  2. Enter the date from which the excise details are applicable from.
  3. Enter the Tariff Name for which the excise details are being recorded.
  4. Enter the HSN Code.
  5. Select the Reporting UOM.
  6. Select the required Type of Tariff. If the Type of Tariff selected is Non-Dutiable, then enter details for the next period
  7. If the Type of Tariff is Dutiable, then select required Valuation Type.
  8. Enable the option Calc Duty on MRP?, if the duty has to be calculated on the MRP value.
  9. Enter the Abatement%, as required.
  1. Enable Set/ alter duty details to enter Excise Tariff Duty Details.
  2. Press Enter.
