https://help.tallysolutions.com/docs/te9rel51/Voucher_Entry/Accounting_Vouchers/Creating_a_Payment_Entry.htm
Creating a Payment Entry
Payment Voucher is used to record all bank and cash payments, For example: company settles a creditor's bill by cheque.
To view the Payment Voucher entry screen:
Go to Gateway of Tally > Accounting Vouchers
  • Select F5: Payment from the Button Bar or press F5.
Payment voucher can be passed using Single Entry or Double Entry mode by configuring the setting Use Single Entry mode for Pymt/Rcpt/Contra in F12 configuration.
For example: the company settles expenses of Conveyance, Staff Welfare, Postage and Stationery through Cash in one voucher. This entry can be passed in single entry mode where you will be crediting the Cash Ledger only once and the entry appears as shown below.
Note: Similarly the transactions can be recorded in single entry mode even in Receipt and Contra vouchers.
Payment entry in Voucher entry mode:
When you have multiple Debits and Credits in an entry, Double Entry mode is the suggested way of passing the entry.
More:
Creating a Payment Entry with Narration for each Transaction
Use Payment as Contra
Warn on Negative Cash Balance
