https://help.tallysolutions.com/docs/te9rel51/Payroll/Employers_EPS_Contribution_Pay_Head.htm
Creating Employer’s EPS Contribution Pay Head
To create Pay Head for Employer’s Contribution towards Employee Pension Scheme (EPS)
  2. Enter the name of the Pay Head in the Name field.
  3. Select Employer’s Statutory Contributions as the Pay Head Type from the list of Pay Head Types.
  4. Select EPS Account (A/c No. 10) in the Statutory Pay Type field.
  6. By default, Affect Net Salary is set to No. Type Yes, if you want this component to be included in the pay slip.
  7. By default, the Calculation Type field is set to As Computed Value, and the Calculation Period is set to Months.
  8. Select Normal Rounding from the list of Rounding Methods, and type 1 as the rounding Limit.
  9. Select On Specified Formula, in the Compute field, from the Computation On list. The Compute sub-screen appears.
  • Select Basic Pay, in the Pay Head column, from the List of Pay Heads.
  1. In the Effective Date field, enter the date from when the EPS deduction will be effective.
  2. Enter the appropriate values in the From Amount and Amount Upto fields.
  3. Select Slab Types from the List of Slabs, in the Slab Type.
  4. Enter the percentage in the Value Basis field.
  5. Similarly, enter the From Amount, Amount Upto, Slab Type and Value Basis details for the next slab.
  6. Press Enter to accept.
