Let us consider the scenario of sales order to understand the feature of Pre-Closure of Order. In the F2: Inventory features set the following options to Yes:
Allow Purchase Order Processing
Allow Sales Order Processing
On 3-9-2009 M/s. ABC Company received an order for 5 nos of Colour Monitor 17" at Rs. 17,500 each. On 4-9-2009, the total order was cancelled.
Go to Gateway of Tally > Inventory Vouchers > F5: Sales Order
Refer to the topic - Creating a Sales Order for complete information on creating a sales order voucher.
In the sales order voucher, select the party ledger, stock item and in the Item Allocation screen enter the quantity and rate. The Sales Order voucher displays as shown:
As the aforesaid sales order was cancelled on 4-9-2009. Hence, the same can be closed in alteration mode of sales order.
View the sales order recorded above in alteration mode. Click on Pre-Close button or press Ctrl + C key combination to pre-close the total order.
The Pre-Close order completely screen will be displayed. Enter the reason for closure and date in Reason and Closed on fields respectively. Accept the details.
Accept the sales order alteration screen.
For the example mentioned above, the order can be closed completely even from the Item Allocation screen.
Display the sales order in alteration mode. press F12: Configure and set Use Pre-Closure order details to Yes.
Accept the Sales Order Configuration.
In the Item Allocation screen, enter the total quantity in Pre-Close column. On entering the quantity, the field - Reason for Pre-Close will be displayed. Enter the Reason for Pre-Close.
Accept the Item Allocation screen and Sales order voucher.
M/s. ABC Company received an order on 2-9-2009 for 13 nos of Colour Monitor 17" at Rs. 17,500 each. On 3-9-2009, 3 nos were cancelled from the order.
The complete Sales Order Voucher displays as shown:
Press Enter to accept the screen.
In the Sales Order alteration screen press F12: Configure and set Use Pre-Closure order details to Yes. Press Enter key on the stock item to display the Item Allocation screen. As 3 nos were cancelled from the sales order, enter the Pre-Close Quantity as 3 nos. On mentioning the pre-close quantity, the field - Reason for Pre-Closure appears. Enter the reason and accept the Item Allocation screen.
The pre-closed quantity and reason entered in Item Allocation will be captured in Order Details screen.
Accept the Item Allocation screen and Sales Order Voucher.
Note: The purchase order can also be pre-closed by entering the pre-close quantity in Item Allocation screen of Purchase Order voucher in alteration mode. The pre-closed quantity, the last reason entered for closure and the date entered in Item Allocation will be captured in Order Details screen.
'Closure from Sales Order' has been shared with
