To create the stock item
Go to Gateway of Tally > Inventory Info. > Stock Items > Create
In Name field enter the stock item Name. E.g. Aluminium Scrap
Group the Stock item Under the Stock Group Scrap (if Stock group is not created use Alt + C from Under field to create the stock group)
In Units field select the applicable unit of measurement. E.g. Gm
Press Enter to save
Enter the Stock Item Name, Group, Unit, Tariff Classification and enable Set/Alter Excise Details to Yes
In Excise Details screen select Reporting UOM, enable Set/Alter Duty Details to select the duties applicable for the stock item and select the Stock Item Type - others.
Press Enter to save
'Creating Stock Item (scrap, by-products, co-products)' has been shared with
