Job Work Analysis report will also take into consideration of a product produced by passing Manufacturing Journal voucher.
Go to Gateway of Tally > Accounts Info or Inventory Info > Voucher Types > Create
Under Name type Manufacturing Journal.
Under Type of Voucher select Stock Journal.
Set Use as a Manufacturing Journal to Yes.
In the item master creation screen (Building), press F12: Configure (Stock Item Configuration) and set Allow component list details ( Bill of Materials) to Yes.
Accept to save the screen.
Now In the Item master creation screen, set Set Components List to Yes
Then the Stock Item Multi Components (M BOM) screen will be displayed. In Name of BOM specify the BOM Name
Press Enter from Name of BOM to view Stock Item Components (BOM) screen. The completed component list is displayed as shown
Go to Gateway of Tally >Inventory Vouchers > press Alt+F7 > select ‘Manufacturing Journal’ under Voucher Type.
Select the Product under Name of Product.
Select the appropriate Godown (Job/Project).
Enter the quantity.
Sub-Component items will be displayed automatically.
Enter the Addl.cost, if any.
Enter the Narration.
'Creating Manufacturing Journal for Job Costing' has been shared with
