There are two ways of altering the Reorder Levels and the Minimum Order Quantities defined earlier.
1. Go to Gateway of Tally > Inventory Info > Reorder Levels
Select the Group of the Stock Items from the List of Groups to display the Specify Reorder Levels screen. Make the necessary changes and accept to save.
OR
2. Go to Gateway of Tally > Display > Statements of Inventory > Reorder Status
Select the Group of the Stock Items for which you want to make changes to display the Inventory Reorder Status screen. Drill down the fields Reorder Level/Minimum Order Quantity to display the Specify Reorder Levels screen. Make the necessary changes and accept to save.
'Altering Reorder Levels and Minimum Quantities' has been shared with
