Inventory reports in Tally.ERP 9 are generated up to the date of the last voucher entry. You can use the customized reports to compare inventory data between different companies, periods of the financial year, and so on.
Printing, altering and displaying inventory reports operates in the same manner as in accounting reports.
Select an item and press Enter to drill down to the next level of a report. The report allows you to drill down until you reach an independent report. To return to the previous screens, press Esc. Any special features, if available, for the currently displayed report, are indicated on the button bar.
This section highlights inventory screens, and illustrates basic levels of customisation.
More:
'Display Inventory Reports and Statements' has been shared with
