https://help.tallysolutions.com/docs/te9rel51/Control_Centre/Unlink_TDL_Configuration.htm
Unlink TDL Configuration
Tally.ERP 9 will switch to Educational mode in case it is unable to read the TDL files. In such a scenario you have to unlink the TDL configuration pack from the respective site and create a fresh configuration pack.
To unlink the TDL Configuration pack from a site, follow the steps shown:
Login to the Control Centre using the Administrator’s Account ID and Password
  • In the Control Centre screen
  • Click Tally.NET Account or press M
  • In My Tally.NET Account(s) screen select the required Account ID
  • The Control Centre screen for the selected account id appears
  • Click Licensing & Configuration or press L
  • In Licensing & Configuration screen select the required site
  • In TDL Config field select Not Applicable
  • Accept to save
Update the license to effect the changes made
