https://help.tallysolutions.com/docs/te9rel50/Voucher_Entry/Order_Processing/Viewing_Order_Position.htm
Viewing Order Position
To view the order position in Stock Summary,
Go to Gateway of Tally > Stock Summary
  • Press Alt + F1 (For detailed view)
  • Press Alt + N > Select Orders & Stock Details
Orders & Stock Details screen is displayed as shown.
Or
  • In the Stock Summary screen, you can add a new column using Alt + C.
  • Sales Order Reports can be accessed through Alt + F7 or Alt + C of the Stock Summary.
Viewing Purchase or Sales Order Outstanding
Go to Gateway of Tally > Stock Summary > Press F9 > select Purchase or Sales Order
Note: Inventory Reports and Accounting Reports can also be accessed through ALL other reports by pressing F9 or F10 (Accounting/ Inventory Reports).
