https://help.tallysolutions.com/docs/te9rel50/Tax_India/Excise_Mfg/Saving_ER8.htm
Re-Computing and Saving the Returns
Saving the ER 8 Return
In the Form ER 8 screen, once the Uncertain Transactions count becomes ‘0’, the details captured in Form ER 8 can be saved.
To save the details click F6: Save button. The details will be saved.
If any transaction is modified/added after saving the return, the values can be recomputed. The recomputed information can either be:
  • Overwritten on the return saved earlier
Or
  • Saved as Corrected Return
To save the changes made in the saved return,
  1. Generate Form ER 8 report for the period for which the return was saved (for example, if the return was saved for the period 1-Apr-2014 to 30-Apr-2014, then view the report for the same period).
  2. The message ‘(The return values might have been changed, press F5 to recompute)’ will be displayed with a new section comprising details of:
  3. Modified Masters: This section displays the count of transactions which are Altered, Created and Deleted
  1. To include the changes made into the report and recalculate the values, click F5: Recompute
  2. Once the values are recomputed, the section displayed for modified masters and transactions will not appear
  3. The recomputed values can be overwritten or saved as corrected return
  4. To overwrite the recomputed information on the existing return, click F6: Overwrite. The message Do you want to Overwrite the Existing Return will be displayed. Press Enter to accept and overwrite the data with modified details.
  5. To save the recomputed valued as corrected return click F7: Corrected Return. The message Do you want to Save the Corrected Return will be displayed. Press Enter to accept and save the Corrected Return.
  1. The modified Form ER 8 will be displayed after it is overwritten with modified data or saved as corrected return.
