https://help.tallysolutions.com/docs/te9rel50/Advanced_Features/Advanced_Accounting_Features/Print_Multiple_Addresses_in_Reports.htm
Print Multiple Addresses in Reports
You can print the mailing details of the required branches/locations created for your company in all your reports in Tally.ERP 9.
Print Reports
Example: Balance Sheet
  • Go to Gateway of Tally > Display > Balance Sheet > Alt + P.
  • From the Print menu, click T: Titling or press Alt + T.
  • The Control on Report Title screen appears.
  • Under Additional Information, go to Company Address to Print and select the required Address Types from the list as shown:
  • Press Enter.
  • Set the other required options and press Ctrl + A or Enter to go back to the Print menu.
  • Press Y or Enter to print the report.
  • The report will print the selected Company Address as shown:
Print Excise Sales Invoice for Dealers (As per Rule 11)
Click here for details.
Print Multiple Addresses in Vouchers and Invoices
Example: Receipt Voucher
To print the Receipt Voucher with the required address of your company:
  • Select the Receipt Voucher and click on Print button or press Alt + P.
  •  The Voucher Printing screen appears, click T: Titling or press Alt + T.
  • Under Additional Information, go to Company Address to Print and select the required Address Type from the list as shown:
  • Press Enter.
  • The voucher will print the selected Company Address as shown:
Note: Similarly, you can print the required address types for other vouchers and invoices.
