https://help.tallysolutions.com/docs/te9rel50/Advanced_Features/Advanced_Accounting_Features/Altering_a_Currency.htm
Altering a Currency
You can modify or delete a currency master using the Alter option. Rates of Exchange can also be altered from here.
To alter a currency master:
  1. Go to Gateway of Tally > Accounts Info. > Currencies > Alter
  1. Select a Currency from the Currencies list (displayed if there is more than 1 currency)
  1. In the Currency Alteration screen, alter details as required. For more information refer Creating a Currency
Displaying a Currency
The Currency Display screen displays the details and rates of exchange for a selected currency.
To display the Currency screen:
  1. Go to Gateway of Tally > Accounts Info. > Currencies > Display
  2. Select a Currency from Currencies list (displayed, if there is more than 1 currency)
  3. Enter to view the details
Deleting a Currency
To delete a Currency:
  2. Select a currency from the Currencies list (displayed, if there is more than 1 currency)
  3. Press Alt + D in the Currency Alteration screen to delete
Note: You cannot delete a Currency, if it is used in any transaction.
