https://help.tallysolutions.com/docs/te9rel50/Job_Work/Stock_Item_Scrap_By_products_Co_products.htm
Stock Item - Scrap/By-Products/Co-Products
To create the stock item
Go to Gateway of Tally > Inventory Info. > Stock Items > Create
  • In Name field enter the stock item Name. E.g. Aluminium Scrap
  • Group the Stock item Under the Stock Group Scrap (if Stock group is not created use Alt + C from Under field to create the stock group)
  • In Units field select the applicable unit of measurement. E.g. Gm
  • Press Enter to save
Scrap - if Excise Applicable
  • Enter the Stock Item Name, Group, Unit, Tariff Classification and enable Set/Alter Excise Details to Yes
  • In Excise Details screen select Reporting UOM, enable Set/Alter Duty Details to select the duties applicable for the stock item and select the Stock Item Type - others.
