https://help.tallysolutions.com/docs/te9rel50/Data_Management/DM_Import_Data.htm
Import Data
In Tally.ERP 9 you can import data from earlier versions of Tally, Tally.ERP 9 and any third party application using the predefined format of XML.
To Import Data
  • Go to Gateway of Tally > Import of Data
  • The Import of Data menu is displayed as shown.
To read more on the step by step procedure for importing masters, vouchers and synchronization click one of the corresponding links:
  • Masters
  • Vouchers
  • Synchronization
