To create a Purchase ledger,
Go to Gateway of Tally > Accounts Info > Ledger > Create
Enter the Name of the purchase ledger, for e.g., Purchases @ 10%
In the Under field, select the Purchase Accounts from the List of Groups
By default Inventory values are affected will be set to Yes
Set Used In VAT Returns to Yes
Select the required VAT/Tax Class, for e.g, Purchases @ 10%
Press Enter to return to the Purchase ledger creation screen
Accept the Purchase Ledger Creation screen.
ย
Note: It is recommended that separate Purchase Ledgers be created for each of the purchase related VAT/Tax classifications.
'Creating Purchase Ledger for VAT' has been shared with
