https://help.tallysolutions.com/docs/te9rel50/Tax_International/United_Kingdom/Party_Ledger.htm
Party Ledger
To create a ledger for the Supplier,
Go to Gateway of Tally > Accounts Info > Ledgers > Create
  1. Enter the name of the ledger in the Name field
  2. In the Under field, select Sundry Creditors from List of Groups
  3. Set Maintain Balances Bill by Bill to Yes/No
  4. By default Inventory values are affected is set to No
  5. Enter the Mailing Details for the ledger
  6. Enter the VAT Regn. No.
Similarly, create the sundry debtor ledger.
