https://help.tallysolutions.com/docs/te9rel50/Voucher_Entry/Advanced_Voucher_Entry/Adv_Voucher_Entry_in_Tally.htm
Advanced Voucher Entry in Tally.ERP 9
Advanced usage in voucher entry involves using more features of Tally.ERP 9. This would mean entering of data in various pop-up and sub-screens depending on the context and configuration (both F12 and F11) settings.
More:
Voucher Entry using Additional Cost of Purchase
Voucher Entry using Inventory Allocations
Voucher Entry using Tracking Numbers
Voucher Entry using Zero Valued Entries
Voucher Entry using different Actual and Billed Quantity
Voucher Entry using Batch Wise details
Voucher Entry using Mfg. and Expiry Dates
Voucher Entry using Cost Categories and Cost Centres
Voucher Entry using Cost Centre Class
Voucher Entry using Multi-Currency
