Payroll is a default feature available in Tally.ERP 9. Enabling Payroll is a two step process:
To enable Payroll in Tally.ERP 9
Go to Gateway of Tally > F11: Features > F1: Accounting Features.
Tab down to Cost/Profit Centres Management section.
Set Maintain Payroll to Yes.
Set More than ONE Payroll / Cost Category to Yes, to allocate employee cost by creating separate employee categories.
Note: You can enable More Than ONE Payroll / Cost Category option to Yes, where parallel allocation of employee cost/cost centre is required.
Press Enter to accept and save, and return to the Gateway of Tally screen.
The Gateway of Tally screen appears
as shown below:
More:
'Enabling Payroll in Tally.ERP 9' has been shared with
