https://help.tallysolutions.com/docs/te9rel50/Reports/MIS_Reports/Cash_Flow_in_Tally.ERP.htm
Cash Flow in Tally.ERP 9
To view Cash Flow:
1. Go to Gateway of Tally > Display > Cash/Funds Flow > Cash Flow
2. Press ALT+F2, change the period - From: 1-4-2008 to 30-9-2008.
The Cash flow statement is displayed as shown:
For Quarterly Cash Flow:
  • Change Period by pressing F2: Period and set the period, e.g., 1-4-08 to 30-06-2008.
  • Select the option Auto Column from the button bar.
  • You can also select Quarterly (or Monthly or any other period) from the list
Columnar Cash Flow Statement
