https://help.tallysolutions.com/docs/te9rel50/Advanced_Features/Advanced_Accounting_Features/Enabling_MultiCurrency.htm
Enabling Multi-Currency
Enable Multi-Currency feature to view and enter transactions in multiple currencies.
  • Go to Gateway of Tally
  • Select F11: Accounting Features
  • Set Allow Multi-Currency to Yes
  • Accept to Save.
 Multi Currency feature is now enabled.
Currencies menu
Once the Multi-Currency feature is enabled in F11: Accounting Features, you can view the Currencies menu from Gateway of Tally > Accounts Info > Currencies.
More:
Creating a Currency
Altering a Currency
Defining Rates of Exchange
