https://help.tallysolutions.com/docs/te9rel50/Tax_International/Bangladesh/VAT_Adjustment_Class_for_JV.htm
Creating a VAT Adjustment Class for Journal
To create a VAT Adjustment Class:
Go to Gateway of Tally >Accounts Info. > Voucher Types > Alter > Journal
  1. In the Voucher Type Alteration screen, enter the Name of Class, for e.g., VAT Class
  1. Set Use Class for VAT Adjustments to Yes
  1. Press Enter to go back to Voucher Type Alteration screen.
  2. Accept the journal voucher type.
Note: The voucher class is created for enabling the list of VAT Adjustments (flags) in journal. The same is used for recording the adjustments and capturing the values in the form.
