https://help.tallysolutions.com/docs/te9rel50/Control_Centre/Licensing_Configuration.htm
Licensing and Configuration
The Account administrator can configure and surrender a site belonging to an account. The configuration set can be created for each site by the Account/ Site administrator. Further, the Account administrator can allow or restrain the site administrator from making any changes to the configuration set locally.
Change Site Status
To change the status for a Single Site,
  • Under Licensing & Configuration, select License Management
  • The Licensing & Configuration screen is displayed with information related to each site/license serial number, the date on which the site was created, Date and Time of Last Update
  • By default the status is Active. You can surrender your license by selecting Surrender under Status.
    • Active: indicates that the site is in operation
    • Surrender: indicates that the site has been surrendered
Creating General Configuration and TDL Configuration package is similar to that mentioned in Multi Site. Click the links below for more information.
