https://help.tallysolutions.com/docs/te9rel50/Advanced_Features/Advanced_Accounting_Features/Display_Alter_Reversing_Journals.htm
Display / Alter Reversing Journals
View or alter the reversing journal through the Reversing Journals Book under Exceptional Reports.
Go to Gateway of Tally > Display > Exception Reports > Reversing Journals
  1. Select a month to list all the reversing journals for that month. Drill-down to view/alter the entry.
