https://help.tallysolutions.com/docs/te9rel50/Advanced_Features/Advanced_Inventory_Features/Enabling_Job_Costing_in_TallyERP.htm
Enabling Job Costing
The Job Costing feature in Tally.ERP 9 is used to track all the incomes and expenses for a project. Each project or job is created as a Cost Centre. The Cost Centres and Inventory Options (Maintain Multiple Godowns) are integrated in Tally.ERP 9 to enable Job Costing, if the company maintains Accounts with Inventory features.  For companies that maintain Accounts Only, the Job Costing feature will not be available.
To enable Job Costing:
Go to Gateway of Tally > F11: Company Features ( F1: Accounting  features)
  1. Set Maintain Cost Centres and Use Cost Centre for Job Costing to Yes.
  1.  Set Maintain Multiple Godowns to Yes in  F11: Company Features (F2: Inventory Features).
  2. Click Accept to save.
Note: For companies, that Maintain Accounts only, the Job Costing feature will not be available.
