https://help.tallysolutions.com/docs/te9rel50/Maintaining_Company_Data/F11_Features/F6_Add_ons.htm
F6: Add-On Features
Customers, to meet their accounting requirements may purchase customised solutions from Tally Partners/any solution provider. Depending on the customer requirement solution provider formulates the solution. In some cases, a solution may require the introduction of New Feature in Tally.ERP 9 to support the functionality. F6: Add-On Features is a place holder for the features provided in the Add-Ons/Local TDLs loaded.
Example: Fixed Assets module is provided by introducing a new feature Enable Fixed Assets.
On loading this TDL, the related features will be displayed in F6: Add-On Features screen. From here users can enable or disable the functionality.
Go to Gateway of Tally > F11: Features > F6: Add-On Features
