Using Cost Categories and Cost Centres
https://help.tallysolutions.com/docs/te9rel50/Voucher_Entry/Advanced_Voucher_Entry/Using_Cost_Categories_and_Cost_Centres.htm
Cost Centers can be allocated in the vouchers. Activate Cost Centre for the Ledger Accounts that are used in voucher entry.
Note: Activate Maintain Cost Centers and More than one payroll / Cost Category in F11:Features > F1:Accounting Features.
Applying Cost Centres to Ledger Accounts
Example: enable Cost Center for Payment ledger – conveyance account.
Go to Gateway of Tally > Accounts Info > Ledgers > Create/Alter
Set Cost Centres are Applicable to Yes.
Cost Centre Allocation in Voucher Entry
Cost Centre allocations have to be done in the pop-up sub-screens in the main voucher entry screen. The sub-screen is displayed after the amount fields pertaining to the ledger for which cost centers have been activated. Hence, the following is the sub-screen for the ledger Conveyance A/c.
The entire objective of creating Cost Centres is to allocate expenses and revenues to Cost Centres.
After allocating the Cost Centers, the payment voucher entry screen is displayed as shown.
More:
