https://help.tallysolutions.com/docs/te9rel50/Voucher_Entry/Order_Processing/Job_Order_Processing.htm
Job Order Processing
Job Work Out Order
When the principal company intents to manufacture or process goods, raises a Job Work Out Order on Job Worker to process the order.  The Job Work Out order contains the Ordered Item, Quantity, Rate and the Amount. It allows to define the BoM for the ordered item. It also contains the despatch details, the process instruction with regard to duration and nature of process along with the Job Work Out Order Number.
Tally.ERP 9 allows the principal company to have track of raw materials sent and finished/processed materials received. It provides reports on Orders/Components Outstandings, Material Movements,  Stock availability with Job Workers, Stock ageing analysis and Analysis on Job Work such as Issue and Receipt Variance.
To enable Job Order Processing refer Enabling Order Processing in Tally.ERP 9.
Job Work In Order
When the job worker receives an order from the principal company to manufacture or process goods, raises a Job Work In Order on the Job Order received. The Job Work In order contains the Ordered Item, Quantity, Rate and the Amount. It allows to define the BoM for the ordered item. It also contains the despatch details, the process instruction with regard to duration and nature of process along with the Job Work In Order Number.
Tally.ERP 9 allows the job worker have track of raw materials received and finished/processed materials sent. It provides reports on Orders/Components Oustandings, Material Movements,  Stock availability with Job Workers, Stock ageing analysis and Analysis on Job Work such as Issue and Receipt Variance.
More:
Creating a Job Work Out Order
Creating a Job Work In Order
