https://help.tallysolutions.com/docs/te9rel50/Tax_India/Excise_Mfg/Stock_Group.htm
Stock Group
To create a stock group
  1. Go to Gateway of Tally > Inventory Info. > Stock Groups > Create
  2. Enter the Name of the stock group.
  3. Select the required group from the List of Groups.
  4. Enable the option Can quantities of items be added, if required.
  5. Enable the option Set/Alter excise details.
The completed Stock Group Creation screen appears as shown below:
  1. Press Enter.
Click a link below to configure the expense/income ledger:
Configuring Selection of Tariff Type
Configuring Tax Calculation based on MRP
Selecting Multiple Duty Details
