https://help.tallysolutions.com/docs/te9rel50/Voucher_Entry/Inventory_Vouchers/Transfer_Journal_Voucher.htm
Transfer Journal Voucher
Tally.ERP 9 allows you to transfer materials from one Godown to another. The transfer of materials is done using the Transfer Journal Voucher.
To create Stock Journal for Inter - Godown Transfers,
Go to Gateway of Tally > Inventory vouchers > Alt+F7 for Stock Journal and select the class.
  • Pass the stock transfer entry.
Printing Stock Transfer Voucher
Press Alt+P to print the Stock Transfer Journal Voucher
F12: Print Configuration
While printing Stock Transfer Voucher, set the options Destination Godown on Top of Voucher and Print Godown Address to Yes.
  • Enabling the option Destination Godown on Top of Voucher will display the Destination Godown name on the top of the voucher instead of printing as separate rows
  • Enabling the option Print Godown Address will display the godown address as mentioned in the Godown Creation/Alteration screen
More:
Voucher Classes for Stock Journals
Creating Stock Journal Voucher Class
Creating a Consumption Stock Journal
