https://help.tallysolutions.com/docs/te9rel50/Advanced_Features/Advanced_Inventory_Features/Creating_Stock_Journal_Voucher_classJW.htm
Creating Stock Journal Voucher class
Stock Journal classes allow you to handle transfers from one location (Godown) to another, for companies having Multi-Location Inventory and at least two locations/Godowns created. It also allows you to track transfer of materials for consumption.
Note : Refer to Voucher Classes for Stock Journals for additional information.
Go to Gateway of Tally > Accounting Info or Inventory Info > Voucher Types > Alter > Stock Journal  > under ‘Name of Class’ give the name as ‘Transfer’:
  1. Below ‘Transfer - Name of Class’ give the name as Consumption’.
 The Stock Journal Voucher screen, which contains both Transfer and Consumption voucher class is displayed as shown.
