https://help.tallysolutions.com/docs/te9rel50/Job_Work/Enabling_Job_Work_in_TallyERP_9.htm
Enabling Job Work in Tally.ERP 9
In Tally.ERP 9, Job Work feature can be enabled from F11: Features.
Go to Gateway of Tally > F11: Features > Inventory Features
  • Set Allow Job Order Processing to Yes
  • On enabling Allow Job Order Processing option, Use Material In/Out will set to Yes automatically.
  • Set the option Track Stock Item Cost to Yes
Note:
1. Allow Job Order Processing: On enabling this feature, in Gateway of Tally under the head Transactions a new option Order Vouchers will be displayed and 2 order vouchers, Job Work In Order and Job Work Out Order will get enabled.
2.Use Material In/Out: Set this option to Yes, to create Material In/Out entries. On enabling this option Two Inventory Vouchers - Material In and Material Out will be available to record the material transfers.
Use Material In/Out option is associated with Job order Processing. Hence the option gets enabled automatically when Allow Job Order Processing feature is enabled and cursor will not move to Use Material In/Out option to change the settings.
Even though the option Use Material In/Out is associated with Job order Processing Tally.ERP 9 gives the flexibility to enable only Material Transfer In/Out feature without enabling Allow Job Order Processing. Use Material In/Out feature can be enabled where the user wants to use Material Transfer vouchers for any other purpose than Job Work. Example: Material Transfer vouchers used for transfer of stock to Consignment Agent, Branch, inter- odown transfers etc
3. Track Stock Item Cost: Set this option to Yes, if you want to track the cost of stock item from purchase of stock till sale. On enabling this option in Stock Item master Enable Cost Tracking field will be displayed.
For a company in which Job Order Processing is enabled the Gateway of Tally Menu appears as shown
Job Work - Excise Applicable
Many manufacturing industries fall under the purview of Excise. If Principal Manufacturer who is delegating a Job or Job Worker who is receiving Job are registered under excise to generate statutory Form & Reports have to enable Excise Feature in Tally.ERP 9.
To enable excise refer the topic Enabling Excise in Tally.ERP 9 for more details.
