https://help.tallysolutions.com/docs/te9rel50/Control_Centre/Jobs_Recruitment.htm
Jobs & Recruitment
The Jobs & Recruitment is a built-in feature designed to recruit candidates by following the recruitment procedure. Using Jobs & Recruitment, you can:
  • Search for manpower with pre-defined skill sets.
  • Conduct knowledge assessment on topics widely used by the business.
  • Enroll candidates into the main stream business.
  • Conduct recruitment process and accommodate job applications received through any media such as e-mail, walk in candidates and references.
Some of the key functionalities offered by jobs and recruitment are:
Recruitment
Recruit clients and also use recruit only feature
Publishing jobs
Publish job requirements based on the positions vacant
Search and save
Search for appropriate candidates and save the search for future use
Match and access
Match candidates for a job an asses existing employee's knowledge
Track recruitment
Track candidate during the recruitment process
Using Jobs &Recruitments
To perform any functions in Jobs & Recruitment section, follow the steps given below:
  • Select Jobs & Recruitments or press Alt + J
  • Press Enter
The Control Centre screen appears as shown below:
